Hi,
just wondering how long does it take to authoring approx. 45 min video into 1 DVD??
I use Ulead movie factory 5 plus.
the video is 45min video size approx 3GB(DVD quality) I capture it from TV.
THX
Results 1 to 10 of 10
The time will vary. If your source file isn't a dvd spec mpeg2 file, it has to be converted. Conversion time varies by cpu speed and application. So basically, there is no good answer.
Google is your Friend -
A rough average would be about 20-30 minutes if the video is already compliant and Movie Factory isn't reenecoding it.
About an 1:15 to 1:30 if it's not compliant and you have to convert it. *using a 3.0 ghz processor.
There's too many varialbles without more information as to exactly what your computer specs and what you are doing. -
And those default "Motion Menus" and transitions can add alot of time -- so watch if it gets slow while doing "menu" stuff...
I usually turn off motion menus and menu transitions (just to speed up the process). If I really want them, I turn them back on and render while I'm away from my machine...
Regards,
George -
About 20 minutes on a medium-fast PC, if it's DVD-compliant.
my PC is P4 2.4 memory 1G.
what do you mean by DVD-compliant??
i think mine takes ages to burn it coz in 1 hour the encoding still in 33%.
any suggestion how to burn it fast??
like what is the best file format for burning DVD??
i think mine is MPEG2.
thx guys -
<---- Read "What Is DVD"Originally Posted by awadudu"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
There's s big dif as to individual times in encoding, authoring & burning.Originally Posted by awadudu
If your capture is not DVD compliant, it all will have to be encoded.
If it IS compliant...then it will just have to be authored.
GeorgeW is right about motion menus they take time too.
Then it comes to burning time.
Mpeg2 doesn't mean DVD compliant.
Example of one DVD standard compliant, here in NTSC land would be:
720x480 rez...48khz audio, Mpeg2.
There are others too.The Devil`s always.....in the Details! -
Encoding will take ages on a machine like that but if the file is compliant you don't have to reencode... Having said that it you have to encode the video the only thing that will speed it up is a faster machine.Originally Posted by awadudu
Hit the little cogwheel (gear) icon on the bottom left -- do you have the box checked off "Do not convert compliant mpeg files"?
Also, are you editing the mpeg files (like cutting them or something)? If so, then you might be better off Exporting them first, then starting a new project. to EXPORT them, above the timeline there is an arror pointing to the left (Export Selected Clips). Hopefully they smartrender during the export, and then you can start a new project and use the new files...
Regards,
George
AVCHD authoring on Blu-ray with menu and date and time as subtitlte
By edoedo in forum Authoring (Blu-ray)Replies: 5Last Post: 29th Aug 2011, 11:49 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
OK, one more time: IRE levels from AVI capture to DVD authoring
By sanlyn in forum Video ConversionReplies: 3Last Post: 13th Jun 2008, 14:54 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 01:38 -
Burning HD to normal DVD + other questions
By Gaelstrom in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2007, 17:02
