I wonder is it possible to do something about an AVI-file that has the sound recorded/encoded? basicly in the left "speaker" only, i can hear a small sound in my headphones from the right "channel" allso
but i would like to have this file 50/50 on both sides, is there any known tool thath can achieve this?
its only this file thath is like this offcorse, just to clear thath it is not my headphones thath are failing so it sems like this files audio have been recorded/encoded(i dont know what therm i shall use) like this from the beggining
im not good in audio-therms as you can hear, so dont take them 100% i just hope you understand what i mean basicly
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 15 of 15
Open the avi with Goldwave.
Copy the left to the right channel or make it mono.
Save as wav or mp3.
Use virtualdubmod to add the new audio to the avi file under streams->streams list.
Select Video->Direct Stream Copy.
Last File->Save as a new avi. -
Hi again..as expected this tutorials of GoldWave whas a bit tho overwhelming for me to swallow
C:\Program\GoldWave\GoldWave.htm
https://forum.videohelp.com/viewtopic.php?t=160649 (Jan Banan! is a old friend of mine)
Originally Posted by Baldrick
cause im blind and retarded :P -
Have you opened the avi? and you see that one track is silent?
Then you can save it to mono directly under File->Save as and select Save as type: MP3 and select Layer 3 128kbits mono under Attributes. -
1)Download the following and unzip.
process.zip
2)Copy your AVI file into the same folder as your unzipped app
3) RENAME your AVI to INPUT.AVI - If everything is correct, your folder will look like this:
ffmpeg.exe
pthreadGC2.dll
process.bat
input.avi
4) Double click on Process.bat Your "fixed" file will be called output.avi -
Originally Posted by Soopafresh
now there is only one problem left probably, when i use Virtualdubmode and/Open Avi File the movie fails to load
and i get this
- Error Decompressing video frame 0: An Unknown Error Occured /maybe corrupt data.(error code -100)
well i dont even know if shall start to load the AVi like this bu all other movies load correct!
what is the next step for me? -
"It did not work for me"
Please, a little more information would help us to help you. Did you get an "Output.avi" file at the end ?"Quality is cool, but don't forget... Content is King!" -
therefore i tested GoldWave instead
the alternate it's just "open" no "open with" as along as the eye can see -
Right click and see if you have a selection for edit or .......
1. start button>run
2.type notepad and click OK
3. file>open, broese for the .bat file -
Originally Posted by thecoalman
Originally Posted by BaldrickOriginally Posted by Blå_Mocka -
Originally Posted by Blå_MockaJohn Miller
Originally Posted by JohnnyMalaria
but i think this is the info you are refering to?
Data source: DVD
DVD title number: 1
Runtime: 01:39:58
[Video]
Video format: NTSC
FPS: 23.976
Size: 624 x 464
Video bitrate (kbps): 1049
Video codec: xvid
2-pass-encoded: yes
Fast resizing: yes -
i dont mean to sound un-patient/un-thankfull here but what happend? well i understand you all got tired of me :P
but i feel close now to complete this procces
just some last help would be mutch appretitated
5.1 to 7.1 - eac3to? Or just duplicate the sides?
By Asterra in forum AudioReplies: 3Last Post: 20th Apr 2012, 05:03 -
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 08:11 -
My Widescreen TV Is Cropping Out The sides Of My DVD'S.
By big_boi97 in forum Newbie / General discussionsReplies: 10Last Post: 8th Sep 2009, 20:27 -
Merge 2 sides or disks to 1
By chas638 in forum Authoring (DVD)Replies: 4Last Post: 19th Apr 2009, 08:30 -
Black bars on sides of video...
By bla4free in forum Capturing and VCRReplies: 7Last Post: 1st May 2008, 07:55
