    Jan 2007
    Italy
    Hi ... I have a problem with my Pioneer DV-444 player.
    Recently when I insert a bourned DVD the images stack for a little time and the image anvanced showing green squares....
    The problem is the same if I insert an old DVD bourned that was ok ...
    There is a problem with the laser? Can I clean It!?
    Thank you for the reply.
    Bye...
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If the problem occurs with store bought/original discs, then it is a player/hardware issue.
    If the problem only occurs with discs that you have burned, then you most likely have a media issue. The problem often occurs with using cheap/generic media, but can also occur with other media. You can check the DVD Players section for your player and see which media other users have had success using, otherwise it is a matter of trial and error. Try a name brand media such as Verbatim.
    Google is your Friend
