Hi,
I have a PAL DVD backup (I do not have the DVD disk) that has a pretty strange effect. Once I play it, the picture quality changes almost every second. Firt, it is perfectly good but in a second it gets blured but after that it gets again perfectly good and again blured. This goes on and on and on.
I would appreciate your advice what it is and how to fix it. Thank you!
If you mean the image pulsates then you have a backup done with a transcoder that didn't do low bitrates too well. DVD Shrink used to do this before Deep Analysis and AEC was introduced. Basically you would get a nice clean image on the I-frame, then it would become progressively softer through the GOP until the next I-frame, when it would sharpen up again.
If this is what you have, then you are basically SOOL. There is nothing you can do to fix it.Read my blog here.
Yes ... and ?
You havent told us the method of viewing here ...
1 : example ...
This effect is similar with some setups where the dvd player's output , is connected to a stereo vcr , because the tv dosent have rca input's ... in this case the stereo vcr cannot handle the video signal correctly .
This affect's both dvd content , with or without macrovision protection .
In this case you need a video stabalizer to interface between dvd player and the vcr to control the issue ... or buy a combo unit ... less clutter and cable's .
The "poor transcoder" factor , is extremly rare ... and is more caused by incorrect user input settings during the backup phase .
Most would atleast playback the final result's on the pc before burning to media .
Issue with media type used ... if from dvd player , could it not be a possibilty that you are playing from dvd+ ... some have issue with the play back of this format .
If you use a combo switch of any kind , check the connections are a tight fit ... loose or poor connections can also cause similar problem's . -
Thanks.
It is on my PC and I watched it on the monitor screen. I never tried it on TV as I assume it will be just the same. -
My first thought is to agree with guns1inger. It's also called a "pumping" effect, caused by removal of DCT data and therefore accumulated errors. In your description you say it happens almost every second, which is roughly what one might expect in a GOP (Group of Pictures).
Is "pumping" or "pulsating" an apt description?Pull! Bang! Darn!
Strange shaking effect in recording while moving the videocamera
By anegroo in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2010, 09:25 -
Humidity effect on dvd players
By proswife in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Nov 2009, 01:17 -
trailing effect on dvd
By D_Shives in forum Authoring (DVD)Replies: 12Last Post: 30th Jun 2008, 07:42 -
Event crop in Sony Vegas creates a strange effect
By Srivas in forum EditingReplies: 5Last Post: 23rd Mar 2008, 22:23 -
Comb effect seen in TV with DVD player!
By hanugro in forum Video ConversionReplies: 3Last Post: 11th Dec 2007, 00:00
