DVD players come with limitations ("capacity") on the number of jpeg still images one can view from a CD. I have only found this spec by calling the maufacturer's higher-level (not entry-level) tech support or engineer, this spec is not listed on web sites.
Would like to know which players can support viewing 5000 low resolution jpeg images on a CD-R. Would be nice if it supported multiple folders instead of only a root, for viewing mobility.
Results 1 to 1 of 1
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
Help putting jpeg on a dvd!!
By ksorvick in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 15:02 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 10:23 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 19:57
