My ADS Pyro A/V Link somehow hangs ALL of my capture programs as soon as I tell the software to start recording.
My PC: Pentium 4 dual core 2.x GHz with 2GB RAM running Windows XP Home SP2. Firewire is through D-Link DFB-A5 PCI card. There are no other PCI cards.
I can hook up external HD to the firewire port and transfer files fine. When I plug in Pyro to the same port and tell Windows Movie Maker to record, the application freezes until I power off Pyro. And nothing was captured. I also tried Premiere Elements 2 and DVIO. The same Pyro does not cause this problem on my laptop. The laptop drops too many frames, so I want to use my desktop PC. I think I once had it working (almost 1 year ago).
For the past 2 weeks, I've been trying out a lot of tools mentioned in this site. Could one of them be causing this problem? Has anyone had this problem before? I found out some people had firewire problems or the application hanging AFTER the capture but nobody else seems to have reported this problem.
Could you suggest something I could try to identify the problem? Thanks in advance.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
I may have too many video programs- I cannot get my capture to work
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2010, 00:45 -
Capture Freezes on all programs
By Justinpd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 18:05 -
what other programs can I use for a Dazzle capture device
By reniett in forum Capturing and VCRReplies: 2Last Post: 8th Sep 2008, 01:08 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05
