Hi, I've been hunting all over the internet to see if anyone else has experienced this problem, as I don't know if I have a faulty machine here or if I've simple not set it up correctly.
My DVD player (Toshiba SD-160 (the silver one, not the black snazzy thing that keeps popping up in searches)) keeps flickering to black at random intervals whilst playing DVDs, changing the size format on the screen back and forth before settling on one for a few minutes and then flickering again. This can go without happening for up to 20 minutes, but can also go into a sort of 'spasm' and keep happening every couple of seconds. Irritating as hell.
It's definitely not the TV as the TV's setup menu doesn't vanish when the screen flickers, but the DVD player menu does, and I've already gone through the manual to no avail.
Any and all help would be appreciated.
Thank you.
~ Krax.
Sounds like a hardware issue. Could be the DVD player, cable, or the input on the TV. If you have another DVD player, you can use it to eliminate the cable and TV input.
Google is your Friend
8 Hour T-160 VHS tape, what are good VCR's for playback?
By daysaf00 in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2012, 12:21 -
Western digital external hard drive 160 gig
By pantangs in forum ComputerReplies: 2Last Post: 15th Jun 2009, 17:33 -
Subtitle nightmare
By willshakespeare in forum Authoring (DVD)Replies: 2Last Post: 10th Jun 2008, 22:21 -
Need some help with.. intex Model No: IT -160
By planetx in forum Capturing and VCRReplies: 1Last Post: 25th Mar 2008, 12:36 -
Toshiba RD-XS35 DVD Player/Recorder with 160 GB Hard Drive
By kevinmdujnic in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Jun 2007, 02:14
