Hi all.
I have converted several mp3 music files into the ac3 format just to make an audio-only DVD in DVD-lab Pro. But before authoring, I would like to hear the resulting ac3 files. Which software should I use to play these ac3 music files? I've tried Windows Media Player but it seems it does not recognize this kind of files.
I'll appreciate your help.
Thanks in advance,
Mário
Check <--Tools. Get AC3 directshow filter. Now you can.
Scott -
Thank you for your answer, but...
OK I got the tool; but now, where and how do I install it? As this is a filter (?), is it associated with any other video reading software?
Looking forward to your reply!
Mário -
If you have installed ac3 filter you should be able to play .ac3 files using wmp. File->Open and select any file or double click on a ac3 file and select wmp as player.
What format do you listen to your computer music files?
By johns0 in forum PollsReplies: 14Last Post: 10th Nov 2011, 08:36 -
AC3 music/dialog is split. Any way to combine the two?
By silvertoaster in forum AudioReplies: 1Last Post: 23rd May 2011, 19:34 -
how can we know that a group of music files have cbr or vbr?
By sumeshkri in forum AudioReplies: 5Last Post: 11th Oct 2009, 12:15 -
Transferring Music Files
By mccoady in forum ComputerReplies: 5Last Post: 14th May 2008, 12:41 -
mp3 music files and dvd
By sumeshkri in forum Newbie / General discussionsReplies: 12Last Post: 28th Feb 2008, 11:32
