The last couple times I tried to join 2 AVI files, it cut out the last 20 min to half hour of the 2nd AVI. Can anyone help me out, or suggest another program to join video files for the mac. Any help is appreciated!
I use VisualHub for joining f.avi file and for making them into DVd. Very easy; Just load your .avi
file. click on the stichs videos together box and hit start. Depends on your Mac's speed and the lenght of the files. Also it is great for making episodes DVD's and converting file to other formats. Check it out. -
You can use the Save As AVI component for QT Pro included in the Extras folder that comes with MPEG Streamclip to edit, mix or join AVI or MOV files and save them into an AVI container without recompresing audio and video.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22 -
when joining 2x700mb .avi files with ffmpegx the result is 1.37gb
By isaachunt in forum ffmpegX general discussionReplies: 2Last Post: 25th Jul 2007, 02:26
