    Jan 2007
    Can someone tell me how to get these free Mp4 Videos to work on my Ipod? I found this site: http://onlyfreemoviesandvideos.blogspot.com and saved the videos to my PC, but I can’t figure out how to load them into my ipod?
    Is there a program I need?
    Sorry if this is a dumb question. Any help is much appreciated!
  2. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    What flavor are the videos? MPEG, AVI's, MP4's, WMV?
    More than likely they need to be converted. Many tools to choose from. My personal preference is Nero but there are others out there.
    https://www.videohelp.com/tools?toolsearch=ipod
    Here are the video requirements for 5th generation ipods
    H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per sec., Baseline Low-Complexity Profile with AAC-LC audio up to 160 Kbps, 48 kHz, stereo audio in .m4v, .mp4, and .mov file formats;
    H.264 video, up to 768 Kbps, 320 by 240 pixels, 30 frames per sec., Baseline Profile up to Level 1.3 with AAC-LC audio up to 160 Kbps, 48 kHz, stereo audio in .m4v, .mp4, and .mov file formats;
    MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per sec., Simple Profile with AAC-LC audio up to 160 Kbps, 48 kHz, stereo audio in .m4v, .mp4, and .mov file formats
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Duh...... iTunes?
    If you attach a VIDEO iPod to your computer it will load playlists you create in iTunes.
    put the files in Documents and Settings\UserNAME\My Documents\My Music\iTunes\iTunes Music
    then drag them to the MUSIC or LIBRARY entry on iTunes (7 calls the library 'MUSIC'now)
    Look for SYNCHRORIZE with iPod in Prefrences
    If you don't use iTunes its a hack (there are many to get files on your iPod)
