I'm trying to convert avi to dvd (pal) with TMPGEnc v 2.5.
I'm doing it with tmpg.. dvd pal template without changing nothing, and always get:
" THE SAMPLING RATE IS NOT PERMITTED WITH SELECTED MPEG-2 LEVEL " ????? someone ?????
Also not understandable - both dvd pal templates are setted to 29.97 fps instead of 25 --> how can I change it ??
Hit the LOAD button inside the program (lower right) and inside the Extra folder is a file named unlock.mcf which when loaded will allow you to change the settings on the frame rate. I loaded the DVD template and also got 29 fps. Hope this helps.
demers669 Thank you for your quick reply
I'll try it tomorrow and let you know if it went O.K.
Thanks again
Doron
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 08:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 17:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 08:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09
