hi, i have a problem finding where i can change the destination for the captured. The program is curently capturing it to my documents but i want it captured directly onto my hardisk instead. Anyone can help??
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19 -
Using HD PVR Capture Module, then placing video in Sony Vegas....
By damonj_3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2011, 14:02 -
Can't capture video with Sony Vegas using my HP media center
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 10:45 -
Which format is best to capture and edit from DVD's in Sony Vegas
By fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 08:38 -
Sony Vegas Pro 8 Capture in 16.9
By Ben17 in forum Capturing and VCRReplies: 18Last Post: 25th Apr 2008, 02:30
