I searched on the other discussion, but the solution there didn't work for me. I've been using ffmpegx for a couple of years now, but now it will go to start to convert an avi file to another avi file with subtitles, but it starts and dings finish right away. There is an output file that is 0kb. I'm using a intel mac mini and installed the files correctly, but it still doesn't work. What's funny is that it worked a few months ago, but when i went to convert something recently, it just stopped working. It's starting to drive me a little bonkers. Any input would be appreciated. Here is the ouput progress file if it helps. Thanks.
Encoding started on Tue Jan 9 23:01:15 EST 2007
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
FIXME:Hardenabling SSE and SSE2 without detection
Mac OSX static build for ffmpegX
CPU: Intel (Family: 6, Stepping: 8)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x2f9da614
AVI file format detected.
VIDEO: [DX50] 704x396 24bpp 29.970 fps 2134.6 kbps (260.6 kbyte/s)
[V] filefmt:3 fourcc:0x30355844 size:704x396 fps:29.97 ftime:=0.0334
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
SUB: Detected subtitle file format: subviewer
SUB: Read 837 subtitles.
SUB: Adjusted 207 subtitle(s).
xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=704 h=400]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
MP3 audio selected
VDec: vo config request - 704 x 396 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
