Hi,
How I can filter mpeg audio (44,2kHz stereo) so that some low frequence humming and creaking will cut down to be less disturbing? Humming sound lot a like 50 Hz generated by power supply voltage and it's recorded on audio track. Maybe then video was captured there was some kind of grounding loop. Anyway is there any good software to help me to get rid of that...
-W
Firstly, you will have to decode your MPEG audio back to uncompressed PCM WAV first (or if you still have your original uncompressed use that). Winamp can decompress the MPEG audio and write it to a WAV file for you.
Then, use CoolEdit 2000.
Find a silent section of your audio and select/highlight it.
Click on Transform --> Noise Reduction --> Noise Reduction
Click on the button marked "Get Profile from Selection".
Then select your entire WAV file.
Click on Transform --> Noise Reduction --> Noise Reduction --> OK.
Save and re-encode your audio to MPEG.
Regards.
Michael Tam
w: Morsels of Evidence
(VHS to DVD) AVI filtering vs. straight MPEG; Post your comparisons
By darito in forum Capturing and VCRReplies: 37Last Post: 2nd Apr 2012, 04:26 -
Filtering during MPEG capture
By TB Player in forum Capturing and VCRReplies: 9Last Post: 31st Dec 2010, 18:53 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43 -
Audio Filtering Program
By dawson54 in forum AudioReplies: 6Last Post: 13th May 2008, 08:10 -
Filtering Buzzing Noise from Audio
By Tchail in forum RestorationReplies: 4Last Post: 12th Sep 2007, 23:49
