The last couple times I tried to join 2 AVI files, it cut out the last 20 min to half hour of the 2nd AVI. Can anyone help me out, or suggest another program to join video files for the mac. Any help is appreciated!
There is apparently an ffmpegx bug that fails to join files that would make a file of larger than 1GB; search the forum for the discussion. I've consequently used D-Vision 3, from www.objectifmac.com, but one needs to read techical French to understand the manual. However, I could use it without a problem.
thanks a lot for the help. I'll give D-Vision a try and let you know how that goes for me.
Monkey Law - A webcomic for the highly evolved.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30
