Hi, I just had a question about using CCE. Can doing too many passes result in worse video quality than doing a few less passes? What I'm trying to ask is: will doing 9 passes always result in better quality than doing, say, 6 passes? Thanks!
After around 3 - 4 passes the difference is minimal, and after 5 passes can only really be seen in a bitrate viewer as a smoother curve, and not in any practical, visual sense. It won't (or shouldn't) get worse, but it won't be anything you will be able to see either. I long ago gave up wasting time on anything more than 3 passes (in CCE speak, that 1+3). Most encoders only do two passes, including the analysis pass, and some rival and surpass CCE in image quality. The laws of diminishing returns are unforgiving.
So in answer to your question, 9 will only be better than 6 at a mathematical level, and 6 will only be better than 3 by around 0.005%, but take twice as long.Read my blog here.
A simple question on Two passes Xvid Encoding,using GordianKnot(not autoGk)
By avengerevenge in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 07:46 -
More than 2 passes
By marioval in forum Authoring (DVD)Replies: 6Last Post: 15th Mar 2010, 05:59 -
ConvertXtoDVD encoding passes
By leghorn in forum Authoring (DVD)Replies: 5Last Post: 6th Aug 2009, 07:42 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33
