Am trying to backup a DVD using Smartripper and TMPGEnc.
The DVD contains 7 VOB files - all of which are the standard 1GB except for the last VOB file.
Smartripper can only rip approx. half of VOB file number 1 (about 580KB) which means that there are about 12 min. missing in the movie.
Any suggestions are more than welcome.
Otto
1. Are you ripping in "Movie Mode"?
2. Did Smartripper give you any error messages?
3. Have you actually tried converting yet?
There is a possibility that the first VOB file contained alternate titles (e.g., a trailer) / alternate angles / seamless branching that are not part of the main movie. If you rip in "Movie Mode" then Smartripper will not rip those parts that are not relevant to the main movie (so only half the vob will be ripped).
If this is the case, there is no problem at all. Continue converting as you normally would.
Regards.
Michael Tam
w: Morsels of Evidence -
It's possible that the DVD is scratched. I have had this happen to me before. Give the disc a good clean with alcohol and try ripping the chapters that you are missing, rather than the whole VOB file.
Incidently, I always rip chapters rather than VOB's, it also allows me to split the movie into two sections before I encode anything! -
this problem for me has always turned out to be a dirty or scratched disk.
Otomann,
i'm gonna hafta go with vitualis on this one. try encoding the movie and watching the rip. or...if you don't wanna go that far...just check out the vobs directly with windvd or powerdvd. skip to the ending of vob 1 and see if it continues onto the beginning of vob 2. if not, then there's a problem.
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 16:53 -
Close Encounters of the Frustrating Kind
By fazza8 in forum Blu-ray RippingReplies: 10Last Post: 15th Sep 2009, 12:12 -
can unnecessary VOB cells be not only blanked but deleted?
By q3mi4 in forum Newbie / General discussionsReplies: 0Last Post: 30th Oct 2008, 09:01 -
Extract Cells from dvd with memcoder
By banon in forum LinuxReplies: 0Last Post: 2nd Oct 2008, 01:15 -
Chapters or Cells
By wulf109 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 16:40
