I just had a problem where Tsunami DVD Author Pro 2 wouldn't accept the VOB file created from my Liteon 5001 as it says that the Mpeg II audio is non standard. I was under the assumption that it was "optional" for the NTSC standard but I want to make sure. The older version of DVD Author (1.5 and 1.6) do not say this at all when creating discs from Liteon and other recorders that use Mpeg II audio.....
http://www.mpeg.org/MPEG/DVD/General/Order.html just $5000 ...
some info http://www.dvddemystified.com/dvdfaq.html#3.6.2 -
It's correct.
Look at the "What Is DVD?" section <-- if you're not convinced.
When it says "optional" that means AS AN ADDITIONAL format stream. It is NOT standard to use it in NTSC as the only audio format stream on a disc.
You can take my word for it, or you can get the ACTUAL standards from the DVD Forum. You'll have to become a member of the forum first (~$2515US), plus you'll have to sign an NDA and a few other applications, and then pay for the DVD-Video and DVD-ROM books (~$5250US).
Otherwise, you could try MPUCoder's site, where (AFAIK) he and others have used reverse engineering to deduce what (most) all the parameters of the spec are.
edit: Note that use of MP2 audio (only) probably will still work OK for a good majority of NTSC players, but that it's not guaranteed and could be flakey on some machines. -
Weirdly enough my Panasonic E80H is what I use for testing these "non standard" discs bitset to DVD-ROM on +R discs. It hasn't failed to play one yet with full audio. And again, using the earlier version of the program gives no such warning.
Oh yeah, the disc I just burned as non standard works (once again) in the E80H..... -
I guess the standards were set long before the Chinese took over the market and ended up not wishing to pay royalties on those expensive audio codecs. As far as I know, they aren't paying anyone for the Mpeg-2 audio format....
Is it possible to find the actual stream URL for Air1 to play in WMP/VLC?
By AshleyQuick in forum Video Streaming DownloadingReplies: 4Last Post: 4th Sep 2011, 23:36 -
1080p Standards?
By thezanny in forum Video ConversionReplies: 4Last Post: 17th Aug 2011, 11:37 -
DVD Maestro - Timeline longer than the actual video file
By alfini in forum Authoring (DVD)Replies: 5Last Post: 15th Nov 2010, 16:49 -
Unable to find "Play next clip" when authoring DVD
By zonag5 in forum Authoring (DVD)Replies: 4Last Post: 16th Oct 2010, 02:50 -
PAL HDV encoding DVD to play on all DVD/TV standards
By ivo in forum MacReplies: 7Last Post: 11th May 2007, 21:26
