how can i extract the audio from a dvd menu or simply record it? i'd rather not record it using the microphone on my laptop. a direct line that would produce a clean track is what i'm looking for. anyone know of a program that can record it directly from the dvd?
pgcdemux, https://forum.videohelp.com/viewtopic.php?t=313743 , the step about demuxing. You should then get an audio file like .ac3 that you can convert to wav using for example belight.
Or play it and record with something like total recorder. -
i tried pcgdemux and had no luck. i thought it worked right off the bat, but when i played the resulting file, it was full of clicks. i switched to your other suggestion of total recorder and all went well - after i tried a bunch of players willing to play a dvd without lag on my system. media player classic is great by the way...power dvd sucks.
anyway, while i still had the file open in total recorder, i tried playing a saved copy in itunes and it came out with all kinds of clicks in it, but once i closed total recorder, the saved wav played perfectly in every player i tried it in. thanks for the help. later. -
The clicks are associated with the demuxing of the audio from several vobs as a single file ... while this should have no affect upon the main title , it dose when it come's down to menu's ...
You should demux menu vob as a separate file only after the menu has been disassembled ... some are simple , other's are not .
Pgcdemux should be capable of doing this work , but then you need to figure out the required setting's according to the structure implemented .
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Sometimes no audio when recording DVD using DVD MovieFactory 5 SE
By JohnDoe1981 in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2011, 12:02 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
Recording pc video/audio out to itself - how do I avoid audio reverb?
By yoda313 in forum Capturing and VCRReplies: 4Last Post: 18th Feb 2008, 19:27 -
Recording new audio track for DVD
By mindfield in forum AudioReplies: 0Last Post: 18th Jan 2008, 13:30
