  1. I am having problems with my RCA DVD,VCR COMBO.The problem I am having is that I can't get my clock to set at the correct time.When I set it up first, the time stays correct until I turn the unit back on again.It will not stay correct for any amount of time.Even cuttting the power to the unit for a period of time does not help me. By not having the corect time, I can't record anything without any hassle.The time differnce on the clock seems to be at least 5 hours in the difference of what Ineed it to stay at.I have also noticed that the VCR channel numbers seem to gradually change on their own when they are in VCR mode as opposed to TV mode. The unit itself is out of warranty now, so that option is out.I am running out of ideas here to try, and any help would be greatly appreciated.
    THANKS GARRY!!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Some players have a menu option for how to set/adjust the time. Usually AUTO or MANUAL.
    Google is your Friend
  3. As per your suggestion,i gave it a try.I also disconnected the player from the outlet and left disconected for 2 days.My time seems to be staying correct now,thanks.
    Thanks for the help, greatly appreciated, ANGUS46 ...
    GARRY
