There's nothing strange about that. CloneDVD is a single threaded application and it is somehwat I/O limited. The X2 3800+ has two cores running at 2 GHz, the 3400+ has a single core running at 2.2 Ghz. (Each core of the X2 is very similar to the single core of the 3400+.) In cases like this the faster clocked single core will win.Originally Posted by Lul2x
Try running a second CPU hungry task while the CloneDVD is transcoding. See who wins then!
Results 31 to 36 of 36
I don't have CloneDVD -- I don't know if you can run two instances of it. But most video encoders are multithreaded and benifit from multiple cores or multiple CPUs. I use TMPGEnc Plus, CCE, Xvid, Divx -- all are multithreaded, some better than others. I know Sony Vegas, Mainconcept, Premiere, etc are also multithreaded. Most games aren't multithreaded, at least not to where they benifit much from multiple cores.
thanks for the reply. How do you find out if a program is multi-threaded? Sorry for my ignorance.
If a program is multithreaded the developer's site will usually mention it as a feature.
I can think of at least two possible explainations:
1) CloneDVD is single threaded so the second core doesn't matter and since the clock speed is higher on the 3400+ it performs better
2) It's a typo and someone entered the wrong time for the 3800+ x2 in this test
Looking at the rest of the results would seem to support #1 until you do some math and realize that the difference in clock speed isn't enough to explain the difference in results.
Perhaps both #1 and #2 are true.Go HP Slimline!
cpu upgrade
By hudsonf in forum ComputerReplies: 25Last Post: 20th Apr 2012, 10:15 -
CPU upgrade possibility
By zzyzzx in forum ComputerReplies: 10Last Post: 2nd Feb 2011, 18:12 -
thoughts on upgrade options
By deadrats in forum ComputerReplies: 13Last Post: 26th Jan 2009, 22:07 -
CPU upgrade question
By mysts in forum ComputerReplies: 35Last Post: 23rd Dec 2008, 02:15 -
cpu upgrade for 1080p mkv files?
By mjd113 in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Jan 2008, 15:51
