Skip-Away uses a special combination of solvents and pressure to heat the plastic, essentially melting the surface, then pressing it back into shape so it's smooth and clear again. (Traditional disc cleaners either grind off layers of plastic or fill in scratches with wax. Venmill describes its OptoClear process as akin to "ironing a shirt.")
See :
http://tech.yahoo.com/ces/null/11882;_ylt=AiQfFy0yNnan7lYmlW_fD4jxLJA5
Results 1 to 9 of 9
Interesting, but I was reading about one disc taking 30 trips through the machine. It may be more feasible to just buy another copy of the disc again.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Looks nice!
Wish it came under a $100 pricemark...
$249 system, as it sez...
"designed for rental outlets, high-end home theater freaks, and gamers"
Puts it WAY over my meager budget.The Devil`s always.....in the Details! -
Unless you got Parkinson's and two hooks for hands, it seems cheaper to just repurchase the disk.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
There is a market for this. For keeping my archive on a perfect condition, I wouldn't say no to get one of those...
I couldn't even say that machine would pay for itself in 10 years let alone right away..like the member said earlier, take care of your stuff and you will not have problems..
http://www.dondivamag.com
:) This site is the Best thing since slice bread :) -
Maybe a great machine for DVD rental sites.
I'm thinking the DVD better be spotlessly clean or you could 'iron in' a chunk of dirt and make all these efforts useless.
I guess I'm a little surprised that you could 'melt' the plastic layer without distorting the disc. But if it works....... -
Thing is, Ironing/Melting and Abrasives/Polishers are modifying the outer layer, which was originally manufactured to very precise dimensions with very tight tolerances. Once applying these things, yes they may do the trick temporarily, but they are also permanently ruining those tolerances. There is an acceptable level of thickness difference, opacity difference, approach angle difference, etc. which these devices are encroaching upon. How much is too much? You probably won't know until it's too late.
For a 1-time fix, it's probably good odds that it's OK, but certainly repeat usage is a NO-NO. Fix once, then immediately copy...
Be careful.
Scott -
Well said Cornucopia. I don't take any chances once I manage to get an unreadable disc recognized again. At that price it would have to be a last,last resort if nothing else worked and you were unable to buy the disc again. redwudz had anoter good point. I imagine it would since it says it will clean smudges and fingerprints.
You can fool some people all the time,you can fool some people part of the time, but you can't fool everybody all the time
DVD Scratches HELP
By Goonies in forum Authoring (DVD)Replies: 1Last Post: 27th Jan 2010, 13:46 -
horizontal white scratches - VHS capture
By Scott L in forum RestorationReplies: 7Last Post: 29th Jun 2008, 22:07 -
reducing data loss from scratches
By Chipp in forum Authoring (DVD)Replies: 4Last Post: 17th May 2008, 17:38 -
filtering scratches/bands
By AlanHK in forum RestorationReplies: 0Last Post: 4th Oct 2007, 06:00 -
Is it the scratches or my burner?
By LittleQueenie in forum DVD RippingReplies: 3Last Post: 1st Jun 2007, 00:35
