  1. I have downloaded a 2 cd dvd - rip of a movie. but after sometime the audio goes out of sync what i want to know is that is there any way by which i can fix this problem. The files are in Xvid format .avi
    Apr 2004
    Miskatonic U
    Start with the stickies - there are a couple on sync issues. Search also works here.
    Read my blog here.
  3. i know but i already have the rip made by some one else and how do i fix that? other thing is that the problem is with the rip but i dont want to convert it in any other form i want to fix the same avi files
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Is it out of sync all the way through or does it go out of sync gradually?
    He's a liar and a murderer, and I say that with all due respect.
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Try SyncView.
  6. ok will try and let u know if it helped
  7. well i need liitle detail help i mean step by step procedure please
