Hi All,
I have trouble with this device . I do not have support cd for this device . Drivers I download from Plextor , but I am cannot capture from this device . Windows Movie Maker cannot detect this device .Plextor provide free software PlexGoCap , but this not work ... Can You help me ?
thanx
marek
Results 1 to 18 of 18
Hi,
I have the same device, it should work fine with the drivers at the Plextor website, you don't need the CD. A couple of things to check:
1. There are 2 ConvertX PX-M402U models, one has a built in TV Tuner, the other doesn't, make sure you have the correct driver.
2. You MUST install the software on your PC before connecting the PX-M402U for the first time
3. Be sure your computer has a working USB 2.0 port
4. Plextor GoCap is not the most stable capture software, There are others that work better, The latest version of VirtualDub, or CaptureFlux works very well for AVI capture, and Nero Vision Express, Sage TV, Beyond TV work well for MPEG-2 Capture -
Ok , I try nero premieum , where is nero vision . But after I conect this device I canot test this and a cannot capture to divx . Which format is better , mpeg2 or DVD ?
thanx -
Hi Again,
Nero Vision Express is the program, Don't worry about the test it doesn't work for some reason, probably Nero's fault, this capture device IS supported if you look on the Nero website. Use DVD "HQ" for the best MPEG-2 setting, If you want to capture DivX use something else, Nero Vision Express sometimes crashes doing DivX captures but it works quite well with MPEG-2. -
And diference about nero vision from nero premium and nero vision express ?
Ok,
I'm using Nero 7 Ultra Edition, before that I had Nero Digital Pro and both had versions of Nero Vision Express that worked with the M402U. I don't know what Nero "Premium" is, if your version of Nero is older than v6 you will probably have to upgrade. Hope this helps! -
Thanjs very much.I am looking this and video from this device is capture ... I am looking and dvd capture with dvd template 720*480 and mpeg2 720*576 ... And in the forum for device drive is write :
"For MPEG-2 video, we support three types of conversion; Blending, Direct Waving and Interpolating. We use the Blending method by default which gives good results on still images and slow moving images. For fast moving images, the Interpolation method provides best results but this method is not great for still images. The Direct Waving method is great for still images but bad for slow and fast moving images. We will release a new driver in the next week or so and it will be set to Blending by default and will allow the user to change to any of the other methods depending on what type of video they normally capture. From the beta drivers we have sent out, about 50% of people have had their problems cleared up and they are very happy with the quality so we are making some progress. "
can I set this in the nero ? -
FalconG,
My driver doesn't allow for these settings, I don't think you would be able to adjust those settings in Nero, What is the Broadcast Standard in the Czech Republic?? Is it PAL or SECAM ? Maybe there are different setting options for PAL or SECAM. My Plextor Driver is about 1 year old, I will check at Plextor and see if there is a new release so I can see what you are talking about. -
Ckecked the Plextor website, the latest driver is Dec.13 2004, no updates since then.
Wow this is very wierd.
I too am having problems capturing from this device. I have Windows XP MCE installed on my computer. I run the driver installation and then connect the device via USB 2.0. Once I connect, my computer states that it's found ConvertX TV402x loader and loads in the drivers, then it says it found ConvertX TV402U A/V Capture Device, but right when it starts loading in the drivers and says 'Hardware is REady to Use' ... the orange ready to record light on the Plextor device goes off. From then on, my computer recognizes the plextor, but no matter what software I try to use, it won't record due to this issue. It won't even display any video.
Any ideas?
Thanks! -
I have this device and it works great on Linux and Windows.
For Windows try to clean the driver using plextor "Driver Uninstall Utility" first then reinstall the latest driver. Last year Plextor released special edition of "Ulead VideoStudio 8 DVD" that works with ConvertX - PX-M402U. It is more stable than the software that came bundled with PX-M402U.
For Linux, MythTV is the best software for PX-M402U. -
Thank you for the reply guys! Well I have the PX-TV402U. Thing is, I can cap with gocap, but for some reason the device will not work with Intervideo WinDVR5 on XP
Any ideas? -
BTW..here is some more info on my problem: https://forum.videohelp.com/viewtopic.php?t=322786
Make sure DirectX 9.0c is installed then try to run "dxdiag" and make sure that all accelerations are enabled. Also make sure that the Plextor device is connected to USB 2.0 port and that the USB cable is able to make USB 2.0 transfer. I found that some (longer) USB cable could not make proper USB 2.0 transfer.
Another important thing is the driver. For some reason the driver on www.plextor.be has more recent (higher version number) than the one on www.plextor.com. But the most recent driver is not always the best driver.
Good Luck -
Thanks Manokat. I will run dxdiag and let you guys know the results.
I started thinking the ConvertX TV-402U might be having some sort of problem. Mabye it was just a coincidence that it broke at the same time that I installed Vista onto my computer.
So I took the unit to my Dad's PC which is the same AMD HP computer, where he didn't install Vista and stayed with the original operating system that came with the computer, which is: XP Media Center 2002 SP2. Put in the disk. Loaded the drivers. Loaded in WinDVR 5 and then connected the unit to the computer. And IT WORKS!!!!
So I know it's not an issue with the device, nor the drivers that I'm using. It has something to do with my dual booted XP installation. I've tried using both FAT and NTFS when installing XP, and both yielded the same results. I do see a couple of things in my device manager under XP that have a ! next to them..but I can't see those things having anything to do with the plextor!!
I've spent weeks trying to figure this out with no luck and it's so @%!^$^ING FRUSTRATING!!!!!!!!
If any more support you guys can give, it wolud be great! If not I'll keep on trying on my own -
Below is a copy of my dxdiag results. The only things I see in my device manager that have an exclamation mark next to them are:
Microsoft Kernel DLS Synthesizer and something else that says PCI Device
System Information
Time of this report: 2/27/2007, 02:14:42
Machine name: HEINEKEN-PC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.050301-1521)
Language: English (Regional Setting: English)
System Manufacturer: HP Pavilion 061
System Model: RF243AA-ABA M7640n
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, MMX, 3DNow (2 CPUs), ~2.6GHz
Memory: 2046MB RAM
Page File: 212MB used, 3726MB available
Windows Dir: E:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: DirectSound test results: Failure at step 3 (DirectSoundCreate): HRESULT = 0x8878000a (The request failed because DirectSound resources, such as the priority level, were already in use by another caller.)
Music Tab: DirectMusic test results: Failure at step 6 (Activating the IDirectMusicPort): HRESULT = 0x8878000a (The request failed because DirectSound resources, such as the priority level, were already in use by another caller.)
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: The tests were cancelled before completing.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7600 GT
Manufacturer: NVIDIA
Chip type: GeForce 7600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0391&SUBSYS_201F19F1&REV_A1
Display Memory: 256.0 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2006 02:52:00, 4527488 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/22/2006 02:52:00, 3994624 bytes
Device Identifier: {D7B71E3E-40D1-11CF-DA5E-150000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0391
SubSys ID: 0x201F19F1
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Failure at step 3 (DirectSoundCreate): HRESULT = 0x8878000a (The request failed because DirectSound resources, such as the priority level, were already in use by another caller.)
Sound Capture Devices
Description: Modem #0 Line Record (emulated)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
DLS Path: E:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
Test Result: Failure at step 6 (Activating the IDirectMusicPort): HRESULT = 0x8878000a (The request failed because DirectSound resources, such as the priority level, were already in use by another caller.)
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 22:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 06:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 22:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 21:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 2/16/2007 17:38:31, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Failed gracefully, Mic: Not run
DirectPlay Test Result: The tests were cancelled before completing.
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Conexant HSF V92 56K PCI Voice Speakerphone Modem
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 278.0 GB
Total Space: 296.2 GB
File System: NTFS
Model: ST3320833AS
Drive: D:
Free Space: 3.4 GB
Total Space: 238.5 GB
File System: NTFS
Model: WDC WD2500KS-00MJB0
Drive: E:
Free Space: 4.5 GB
Total Space: 9.1 GB
File System: NTFS
Model: ST3320833AS
Drive: F:
Model: TSSTcorp CD/DVDW TS-H652L
Driver: e:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:54, 49536 bytes
System Devices
Name: Hauppauge WinTV PVR PCI II (26xxx)
Device ID: PCI\VEN_4444&DEV_0016&SUBSYS_88010070&REV_01\4&DC2 68A3&0&5080
Driver: E:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/3/2004 15:26:44, 4096 bytes
Driver: E:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/3/2004 15:26:58, 130048 bytes
Driver: E:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 13:45:22, 140928 bytes
Driver: E:\WINDOWS\system32\kstvtune.ax, 5.03.2600.2180 (English), 8/3/2004 15:26:58, 61952 bytes
Driver: E:\WINDOWS\system32\ksxbar.ax, 5.03.2600.2180 (English), 8/3/2004 15:26:58, 43008 bytes
Driver: E:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.2180 (English), 8/3/2004 15:26:58, 90624 bytes
Driver: E:\WINDOWS\system32\vidcap.ax, 5.01.2600.2180 (English), 8/3/2004 15:26:58, 28672 bytes
Driver: E:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.2180 (English), 8/3/2004 15:26:48, 53760 bytes
Driver: E:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.2180 (English), 8/3/2004 15:26:44, 47616 bytes
Driver: E:\WINDOWS\system32\msh263.drv, 5.01.2600.2180 (English), 8/3/2004 15:26:58, 294912 bytes
Driver: E:\WINDOWS\system32\msyuv.dll, 5.03.2600.2180 (English), 8/3/2004 15:26:46, 17408 bytes
Driver: E:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.0000 (English), 8/17/2001 13:06:34, 8192 bytes
Driver: E:\WINDOWS\system32\DRIVERS\hcwPP2.sys, 2.00.0048.24227 (English), 8/15/2006 06:48:12, 177152 bytes
Driver: E:\WINDOWS\system32\DRIVERS\HcwFalcn.rom, 11/2/2005 08:50:10, 376836 bytes
Driver: E:\WINDOWS\system32\DRIVERS\HcwMakoB.rom, 4/20/2005 01:26:20, 14264 bytes
Driver: E:\WINDOWS\system32\DRIVERS\HcwMakoC.rom, 2/9/2006 02:24:00, 16382 bytes
Driver: E:\WINDOWS\system32\hcwPrxA2.ax, 2.01.0048.24201 (English), 7/21/2006 06:20:30, 94720 bytes
Driver: E:\WINDOWS\system32\hcwCCnv2.ax, 2.00.0048.24201 (English), 7/21/2006 06:20:30, 99328 bytes
Driver: E:\WINDOWS\system32\hcwXDS.dll, 1.06.0000.24201 (English), 7/21/2006 06:20:34, 66048 bytes
Driver: E:\WINDOWS\system32\hcwCP.ax, 2.00.24227.0000 (English), 8/15/2006 06:32:22, 95232 bytes
Driver: E:\WINDOWS\system32\hcwECPPP.ax, 2.00.24227.0000 (English), 8/15/2006 06:38:38, 138752 bytes
Name: Conexant HSF V92 56K PCI Voice Speakerphone Modem
Device ID: PCI\VEN_14F1&DEV_2F20&SUBSYS_200C14F1&REV_00\4&DC2 68A3&0&4880
Driver: E:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.04.0005.0000 (English), 11/13/2003 18:18:36, 679808 bytes
Driver: E:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 7.04.0005.0000 (English), 11/13/2003 18:19:48, 210304 bytes
Driver: E:\WINDOWS\SYSTEM32\DRIVERS\HSF_DP.sys, 7.04.0005.0000 (English), 11/13/2003 18:17:00, 1042816 bytes
Driver: E:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0002 (English), 4/9/2003 13:48:08, 11043 bytes
Driver: E:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0002 (English), 4/9/2003 14:01:32, 90112 bytes
Driver: E:\WINDOWS\system32\HSFCI008.dll, 7.04.0002.0000 (English), 11/5/2003 15:02:02, 32218 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_2A34103C&REV_70\4&DC2 68A3&0&2880
Driver: E:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:10, 61056 bytes
Driver: E:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 22:10:08, 53248 bytes
Driver: E:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 2/16/2007 17:38:31, 61824 bytes
Driver: E:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 2/16/2007 17:38:31, 60800 bytes
Driver: E:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Name: D-Link DGE-530T Gigabit Ethernet Adapter
Device ID: PCI\VEN_1186&DEV_4B01&SUBSYS_4B011186&REV_11\4&DC2 68A3&0&4080
Driver: E:\WINDOWS\system32\DRIVERS\m4cxw2k3.sys, 7.42.0001.0003 (English), 3/9/2005 22:12:00, 227584 bytes
Name: NVIDIA GeForce 7600 GT
Device ID: PCI\VEN_10DE&DEV_0391&SUBSYS_201F19F1&REV_A1\4&13D 46659&0&0020
Driver: E:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 3994624 bytes
Driver: E:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 4527488 bytes
Driver: E:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 159810 bytes
Driver: E:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9371 (), 10/22/2006 02:52:00, 581632 bytes
Driver: E:\WINDOWS\system32\nvapi.dll, 6.14.0010.9371 (), 10/22/2006 02:52:00, 212992 bytes
Driver: E:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 5644288 bytes
Driver: E:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 7700480 bytes
Driver: E:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 86016 bytes
Driver: E:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 81920 bytes
Driver: E:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11060 (English), 10/22/2006 02:52:00, 286720 bytes
Driver: E:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 229376 bytes
Driver: E:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 5619712 bytes
Driver: E:\WINDOWS\system32\nvdispsr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 5255168 bytes
Driver: E:\WINDOWS\system32\nvgames.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 3047424 bytes
Driver: E:\WINDOWS\system32\nvgamesr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 3203072 bytes
Driver: E:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 188416 bytes
Driver: E:\WINDOWS\system32\nvmccssr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 458752 bytes
Driver: E:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 888832 bytes
Driver: E:\WINDOWS\system32\nvmoblsr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 2859008 bytes
Driver: E:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 2924544 bytes
Driver: E:\WINDOWS\system32\nvvitvsr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 2973696 bytes
Driver: E:\WINDOWS\system32\nvwss.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 1236992 bytes
Driver: E:\WINDOWS\system32\nvwssr.dll, 6.14.0010.9371 (English), 10/22/2006 02:52:00, 1732608 bytes
Driver: E:\WINDOWS\help\nvcpl.hlp, 10/22/2006 02:52:00, 177897 bytes
Driver: E:\WINDOWS\help\nvwcplen.hlp, 10/22/2006 02:52:00, 55444 bytes
Driver: E:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 10/22/2006 02:52:00, 35840 bytes
Driver: E:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 10/22/2006 02:52:00, 35840 bytes
Name: nForce Memory Controller
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&02
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_02FC&SUBSYS_00000000&REV_A1\3&241 1E6FE&0&10
Driver: E:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&241 1E6FE&0&20
Name: nForce HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F0&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_2A34103C&REV_A3\3&241 1E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_00000000&REV_A2\3&241 1E6FE&0&80
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_2A34103C&REV_A3\3&241 1E6FE&0&59
Driver: E:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 26624 bytes
Driver: E:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes
Driver: E:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 19:56:48, 74240 bytes
Driver: E:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes
Driver: E:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:44, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_2A34103C&REV_A3\3&241 1E6FE&0&58
Driver: E:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_026C&SUBSYS_2A34103C&REV_A2\3&241 1E6FE&0&81
Driver: n/a
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_2A34103C&REV_A3\3&241 1E6FE&0&A0
Driver: E:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.5023 (English), 2/17/2006 11:28:32, 13056 bytes
Driver: E:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.5023 (English), 2/17/2006 11:28:14, 305152 bytes
Driver: E:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.5023 (English), 2/17/2006 11:28:02, 222592 bytes
Driver: E:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 2/17/2006 04:26:58, 9728 bytes
Driver: E:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 2/17/2006 11:26:58, 9728 bytes
Driver: E:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 12/20/2005 18:23:30, 35840 bytes
Name: NVIDIA nForce 430/410 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_2A34103C&REV_A1\3&241 1E6FE&0&78
Driver: E:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 17:52:28, 100736 bytes
Driver: E:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
Driver: E:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 4/24/2006 17:52:30, 289792 bytes
Driver: E:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 07:01:20, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_2A34103C&REV_A1\3&241 1E6FE&0&70
Name: NVIDIA MCP51 Parallel ATA Controller
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_2A34103C&REV_A1\3&241 1E6FE&0&68
Driver: E:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0521 (English), 3/14/2005 07:35:08, 91776 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_2A34103C&REV_A3\3&241 1E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_00000000&REV_A3\3&241 1E6FE&0&50
Driver: E:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 06:00:00, 35840 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 2/16/2007 17:38:31 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 2/25/2007 00:46:05 1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 06:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 23:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 2/16/2007 17:32:25 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 2/16/2007 17:33:52 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:26 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 2/16/2007 17:32:54 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 2/16/2007 17:33:02 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 23:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 23:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 23:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 23:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 23:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 23:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 23:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 23:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:45:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 2/16/2007 17:38:31 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:28:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 13:28:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:28:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 2/16/2007 17:38:31 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:28:40 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:56:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:46 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 15:26:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 15:26:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 13:40:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:48 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0004.0822
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.00 00
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,5.02.0020.0217
ffdshow MPEG-4 Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0003.0851
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.007 9
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0003.0851
InterVideo Audio Encoder,0x00200000,1,1,iviaenc.ax,3.00.0088.0000
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0003.0851
InterVideo Demux,0x00200000,1,2,IVIdemxx.ax,3.00.0088.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
InterVideo Time Shift,0x00200000,1,2,ivits.ax,3.00.0088.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
IndeoŽ video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
IndeoŽ video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
InterVideo Video Encoder,0x00200000,2,1,IVIVENC.ax,3.00.0088.0000
InterVideo Multiplexer,0x00200000,1,1,ivimux.ax,3.00.0088.000 0
InterVideo Demultiplexer,0x00200000,1,1,IVIdemux.ax,3.02.0055 .0000
Hauppauge WinTV Color Format Converter,0x00600000,1,1,hcwCConv.ax,1.17.0390.213 46
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.09.0000.0311
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.000 2
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
File Source (MP3),0x00400000,0,1,mp3Source.ax,
InterVideo Disc Write2 Filter,0x00200000,1,0,DiscRite.ax,1.00.0000.0001
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0004.0008
FLV Splitter,0x00600000,1,1,FLVSplitter.ax,1.00.0000.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.00.00 03.0431
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Minimal Null,0x00200000,1,1,hcwNull.ax,1.17.0110.21125
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0062.0021
InterVideo VBI Decoder,0x00200000,1,1,IvVBIDec.ax,1.00.0000.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00400000,0,1,ndparser.ax,4.02.0004.0008
CyberLink Line21 Decoder (PDVD7),0x00200000,0,2,CLLine21.ax,4.00.0000.6929
Intervideo Disc Read2 Filter,0x00400000,0,1,DiscRead.ax,
InterVideo Wave Wrapper,0x00200000,0,0,IVIwavex.ax,3.00.0088.0000
InterVideo Down Scale Filter,0x00200000,1,1,IVIDownS.ax,3.00.0088.0000
MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0002
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5 145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
XviD MPEG-4 Video Decoder,0xff800000,1,1,xvid.ax,
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
ShoutcastSource,0x00400000,0,1,shoutcastsource.ax, 1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0575
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
InterVideo Stream Renderer,0x00200000,1,0,IviStreamRenderer.ax,1.00. 0000.0001
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 01.0001
InterVideo Pre-scaling Filter,0x00200000,1,1,IVIScale.ax,3.00.0088.0000
FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
FLV Video Decoder,0x00600000,1,1,FLVSplitter.ax,1.00.0000.00 01
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,5.02.0020.0217
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
RadLight MPC DirectShow Filter,0x00600000,0,1,MPCDec.ax,1.00.0000.0003
Hauppauge WinTV Color Format Converter 2,0x00600000,1,1,hcwCCnv2.ax,2.00.0048.24201
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVSD.ax,6.00.0000.3402
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0062.0021
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001.0003
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.000 3
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Hauppauge WinTV SnapShot,0x00200000,1,1,hcwSnap.ax,1.12.21190.0000
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0062.0021
Hauppauge WinTV MPEG Splitter,0x00000000,1,2,hcwSplit.ax,1.15.24073.000 0
AC3Filter,0x40000000,1,1,ac3filter.ax,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
Hauppauge WinTV File Writer,0x00200000,1,0,hcwFWrit.ax,1.15.24044.0000
InterVideo Navigator,0x00190000,0,3,IVInav.ax,5.02.0020.0217
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
IndeoŽ audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0003.0851
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.00 00
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
FLV Source,0x00600000,0,0,FLVSplitter.ax,1.00.0000.000 1
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
InterVideo File Writer,0x00200000,1,0,IVIwrite.ax,3.00.0088.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0 002
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0004.0008
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.00. 0003.0277
InterVideo Still Capture,0x00200000,1,1,IVIscapt.ax,3.00.0088.0000
Nero Digital Parser,0x00400000,0,3,ndparser.ax,4.02.0004.0008
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.000 2
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Hauppauge WinTV File Reader,0x00200000,0,1,hcwFRead.ax,1.16.24062.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0062.0021
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AC3File,0x00600000,0,1,ac3file.ax,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
IndeoŽ video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Voxware MetaSound Audio Decoder,0x00999999,1,1,voxmsdec.ax,1.00.0000.0012
IndeoŽ video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Encoder Devices:
Hauppauge WinTV PVR PCI II Encoder,0x00400000,1,2,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0003.0851
IndeoŽ video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.274 9
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IndeoŽ Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
IndeoŽ video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
Hauppauge WinTV PVR PCI II Capture,0x00200000,6,0,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Multiplexer Devices:
Video Capture Sources:
WDM Streaming TV Tuner Devices:
Hauppauge WinTV PVR PCI II TvTuner,0x00200000,0,2,,5.03.2600.2180
WDM Streaming Crossbar Devices:
Hauppauge WinTV PVR PCI II Crossbar,0x00200000,8,2,,5.03.2600.2180
WDM Streaming TV Audio Devices:
Hauppauge WinTV PVR PCI II TvAudio,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Modem #0 Line Playback (emulated),0x00200000,1,0,quartz.dll,6.05.2600.274 9
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
Plextor ConvertX PX-M401U
By texasdontholdem in forum Video ConversionReplies: 0Last Post: 1st Jan 2010, 15:53 -
Any better capture devices than Plextor ConvertX tv402u?
By Heineken77 in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 16:15 -
Plextor PX-AV200U ConvertX Digital Video Converter Updated
By BJ_M in forum Latest Video NewsReplies: 4Last Post: 3rd Jun 2008, 18:21 -
Plextor convertx px-m402u
By TyWelcome in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2008, 21:43 -
I use the Plextor Convertx but with Premiere Elements, it don't werk!
By Heyjoojoo in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2007, 19:02
