Im moving my current MKV collection onto a XDIVX dvd for play in my DIVX player.
I followed advice from baldrick using alltoavi to convert my MKV to XDIVX, I burned these new files and they played flawlessly. I was extremely impressed.
Later on I decided to take a stab at adding in the second audio channel and the sub channel into the AVI as I read an article where my DIVX player can change audio channel and activate the sub.
I took the pre-made XDIVX file and followed this tut: https://forum.videohelp.com/viewtopic.php?t=266194
I didnt have LAME installed so I just dled and installed it, removed the stream as a wav using the LAME CBR compression algorithm as outlined in that tut.
I burned the newly made file and the dvd player spews out some invalid codec error. I check the file and see the two audio channels are not the same.
GSPOT shows audio channel 1:
Codec: 0x0055 MPEG-1 Layer 3
Info: 48000Hz 192 kb/s tot , Joint Stereo
Audio channel 2:
Codec: 0x0055 (MP3)
Info: 48000Hz 192 kb/s tot (2 chnls)
How can I get channel 2 to have the same properties of channel 1 in a quick manner?
I have over 50 MKV files with 2 audio channels and would like a quick solution to rip the streams and convert them.
Thanks!
I'm afraid I can't help you much, but I did find this interesting article about joint stereo: http://harmsy.freeuk.com/mostync/
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
dvd to mkv/avi with multi audio channel
By vampelle in forum DVD RippingReplies: 1Last Post: 28th Sep 2010, 13:02 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
Multi-audio VOB to Multi-audio AVI?
By kitabata in forum Video ConversionReplies: 2Last Post: 20th May 2009, 02:58 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
