I have been trying to create an audio dvd and have searched the forums for tutorials on the subject, I thought I found one but seemed to lose it. I am familar with the app called Audio DVD Creator and another called Apollo Audio DVD Creator but I'd like to do it from scratch if it is possible.
My standalone dvd player supports mp3 format and DTS, DD2, I have also tried formatting music files to 48,000khz (the dvd standard I mean) with 192kbps using ac3 formatted audio files when I burn those to dvd using nero and also tried to burn it as a data disc to no avail. ( I have read something to the effect of placing a small video along with the audio files on the disc but lost the post . I think I read it here on VideoHelp.com) If theres someone that could enlighten me on this . ( Which encoder or authoring program would enable me to do this?)Thanks Much[/b]
	Here's one using DVD Lab: https://forum.videohelp.com/viewtopic.php?t=300631 There is another similar one: https://forum.videohelp.com/viewtopic.php?t=287574
	Thanks Much Redwudz for the links. I will try it out . Is it possible to do this with TMPG DVD Author?, Ive used DVDLab Pro and Its a little difficult linking menues for me, if IM not careful, but I'll give it a whirl, Again thanks!!!!
	I can now do this with GUI for DVDAuthor, although I have bought a new Home Entertainment System that can play mp3's that I have burned to a dvd disc. Thanks for all the help.
	I did mine with TMPGenc Plus 2.5 and TDA. Use a rediculously low video bitrate and encode the audio to mpeg. The songs show a black screen when playing but the DVD will run all day. I made the menu with TDA including album and song titles.
 Don't laugh...Farnham is THE MAN...
	Very interesting I tried to figure out how to do it with TDA, I now do it with GUI for DVDAuthor even using menus, Id like to try your methodOriginally Posted by hech54
	Interesting Hech54 I do it with GUI for DVDAuthor even with menus. Its very nice and I also use it over TDA. GUI for dvdauthor is lighter and reliable for me all day, plus its FREE,. What more can I say?
  Joined MTS files from Panasonic HDC-SD70, create audio delay...By pleindepuces in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Dec 2010, 16:29
  Create DVD Audio Patch?By Spawn1985 in forum Authoring (DVD)Replies: 23Last Post: 4th May 2010, 00:25
  How do I create a Digital Audio DVD?By chrisf71 in forum AudioReplies: 10Last Post: 25th Jul 2009, 23:00
  Here is how to create PS3 Compatible Files with 5.1 AudioBy pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 01:30
  create dual audio dvdBy jin007 in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2008, 18:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
