hello,
Ive been downloading a series of television shows to watch, and all of them seem to play okay except one episode which has very bad pixelation on a scene change where you can still see parts of the previous scene for a few more seconds. When playing this on my pc or a dvd player as an avi file it locks up although the audio keeps going. When converted to dvd it will play okay on my dvd player but you still see the pixelation. The file size is similar to the other episodes so Im not sure whats wrong? Could I have a bad download and need to redownload this file or can I fix it by running it though some sort of software that fixes these things?
That sounds like a corrupted file or a bad conversion. Not usually much you can usually do except to cut out the bad parts. The player may be displaying the last good frame while it waits for the next good one to come up.
You could try downloading it again, but it may just be part of the file.
Avidemux - Why is there pixelation from stream movie?
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2012, 11:20 -
Scene Detection and Cutter for MPEG File
By klode in forum EditingReplies: 6Last Post: 6th Nov 2011, 19:39 -
Capturing DV tape to one file, or multiple files by scene?
By Obtong in forum EditingReplies: 4Last Post: 12th Jul 2011, 13:03 -
Min DV capture, with auto scene file splitting on the fly
By Hitmandj in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2011, 18:40 -
Pixelation on mkv, mp4 and avi files
By ajkrishock in forum Newbie / General discussionsReplies: 10Last Post: 24th Nov 2010, 07:12
