I downloaded a video file that is in the bin/cue format. It's 801 MB in size. What should I do to get it to play on my dvd player in the best quality possible?
Results 1 to 12 of 12
Burn it to CD with a image burning program. Try ImgBurn, or Nero can do that. But what format is it? A BIN/CUE is just a container that can have just about any format in it.
You might try playing it on a computer first with VLC media player. It should play the BIN file. Then you can also check the format. -
k thx man appreciate it. It's in mpeg 1 format. and here's some other info:
Source: ...... TELESYNC.XViD - VCDUS
Format: ...... Bin/Cue
Chapters: .... Every 5 Minutes
Runtime: ..... 108 Minutes Approx
Video: ....... Mpeg1/NTSC
Audio: ....... 44.1kHz/224kbps/Stereo
Res: ......... 352x240/23.976fps
Size: ........ 801Mb(Bin file) -
It's a VCD format made for a CD. But you will have to burn it in Mode 2 to fit on a 700MB CD. I would give ImgBurn a try first. Then maybe Nero: 'Recorder>Burn Image'.
If no luck with the filesize being rejected, you may have to convert to DVD after extracting the file from the image container. I suspect the quality is pretty poor, so I would view it first before trying to convert to DVD.
Of course this is all covered in the STICKY at the top of the page.
Google is your Friend -
Most likely, not all DVD players support VCD and/or SVCD.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
