late night all...
I think I finally got it, by-golly-geee - that is, the
reduction of the blocks during the opening scene!!
Ok, ben testing soo many scenarious like you wouldn't
believe. And finally, this very late night, I think I
either figured it out or finally hit on it by luck. But,
I'm soooooo tired and my eyes are sooo heavy. What I
think I will do is maybe post a small sample clips for you
all to digest. But, it would help if you ask me where in
the scene you want me to clip and post. Since the scene
(start to fnish) is ~23mb, It would be easier to tell me
where, and I can post a 2 or 5mb size or larger. I can
only post 20mb total. I've also quickly tested other
fast scenes, and I liked what I saw - based on my Apex
ad-500 and ad-1500 dvd players. I'll assume you'll get
better results w/out the Apex models. Oh, and PC play
is pretty good too, thought not so bad considering the
full screen stretch.
Anywas, if you all R interetested, i'll post.
-vhelp
Hi!
It is better to post the way you did it, not the file itself!
Which programs/method/template/parameters/etc
What bitrate, resolution, media type, etc!
Why are there spurious? frames in my interlaced PAL capture - sample clip
By BigMick in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 07:29 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
The Mummy - How to get the forced subtitles
By Mascot in forum Blu-ray RippingReplies: 19Last Post: 20th Apr 2009, 20:01 -
The Mummy 3 - Can't make backup
By mop59136 in forum DVD RippingReplies: 5Last Post: 25th Nov 2008, 10:50 -
New Movie Release -- The Mummy: Tomb of the Dragon Emperor
By vhelp in forum Off topicReplies: 12Last Post: 25th Apr 2008, 11:55
