    Jan 2007
    Turkey
    hi guys
    im trying to add subtitle to a dvd with subtitlecreator. bu @step3 (with vobblanker). vobblanker gives an error like that.
    "ifo has more than one pgc, not supported".
    when i check it on dvddecrypter i see a pgc which is i think unneccesary with main movie. is there anyway to remove it.
    thanks.
    Jan 2007
    Turkey
    is there no suggestion
    Feb 2004
    Australia
    You need to use an updated tool like dvdfab , ripit4me , or pgcedit plus the plugins and add on programs .
    Which ever one you use , rip the whole sod of a thing to the hard drive .
    Then use pgcdemux to grab out the real pgc on it's own .
    You should beable to use vobblanker to deal with the remaining issue , but I prefer to use the pgcedit method .
    Load dvd in pgcedit , locate the title itself , and simply replace this one with the one you got pgcdemux to lift out beforehand , save dvd , and recheck in both pgcdemux and vobblanker ... it shouldnt be there this time .
    Of course when I done this with pgcdemux , I used rejig to reauthor the pulled title before replacing it in pgcedit
