Has anyone tried the Epson printer cartridges on ebay? They are so inexpensive. $2.00 each delivered. How is the ink? Do they leak? Are they OK? If you have experience with them let me know. I'm looking for first hand experience comments.
If you want carts that cheap, get a set from www.rima.com or www.supermediastore.com. You can get a set of all 6 for about $15. They work fine and if you have a problem, it's easier to go right to the source.
- Brett -
I can attest to the cartridges from Rima. I use them regularly and they work fine in my R220.
Thanks. I'll go with the Rima.com. Always had good luck with rima. Just retired my last Photo Stylus 900 and am staring with the R220. Great printer so far.
I have good luck with generic ink for the last 4 years(canon Pixma,Epson c62)from eforcity ebay store
http://search.ebay.com/search/search.dll?sofocus=unknown&sbrftog=1&catref=C12&fscl=1&f...p=1%26fsoo%3D1 -
Has anyone bought Epson compatibles from Megatoners lately? I have been buying from them for the past couple of years with no problems but the last set I got the colors just seem to be off, and wondered if anyone else had similar problems.
Epson R220 on the way out. Can nozzles/heads be cleaned? Really?
By videobread in forum MediaReplies: 13Last Post: 12th Jan 2012, 11:56 -
Epson R220 problem printing on discs
By nwo in forum MediaReplies: 3Last Post: 2nd Jun 2011, 13:15 -
Is Epson R220 now history?
By videobread in forum MediaReplies: 14Last Post: 1st Jul 2008, 13:56 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Ink question for refillable Epson R220 cartridges
By Mahime in forum MediaReplies: 3Last Post: 14th Jan 2008, 20:54
