  1. hi,
    I reinstalled my windows a month ago (new hardware) and reinstalled svcd2dvd 1.52.2.0. It worked fine. But now it doesn't start anymore. The Splashscreen appears and then it just closes down, no error, no processes left in taskmanager. It creates a file "svcd2dvd_.log" with just a "7" in it. Any idea?
    Regards,
    Sascha
    BTW: In V2 I still don't like that you have to exctract the .bin files before processing the rest. in V1 it was just one click for all, now I first have to have until the images are extracted, then doing my things, clicking the stuff together, and then process it.. Ugh! I want my 1-click-solution back
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    i would try to reinstall v1.52 and see if that solves the issue...
    V2 is also one click for bin files isn't it? Load bins, click on "Quick DVD"...
    (i could be wrong - not seen a bin file for a while now)
  3. I tried that of course It still does not work.. same "error" (no error That was my first try.. but I tried it only once, I didn't want to run out of machine licenses I installed V2 then.
    Hmm.. I don't use the quick dvd function, because I create custom menus
    You could make it possible to drag and drop .bin images into VTS Layout That would be exact the same function as in V1 then.
