Last night I hooked up my VCR to my WinFast TV2000. I opened VirtualDub and when I set the capture device to "WinFast TV2000 XP WDM Video Capture (DirectShow) I was able to preview what the VCR was playing as well as capture using HuffyUV @ 720x480 using YUY2.
Today however...I've been messing with it and I somehow messed it up. I can now only preview what the VCR is playing when VirtualDub is set to "Microsoft WDM Image Capture (Win32) (VFW)". I can capture using HuffyUV but I cannot select YUY2 as it says the deivce does not support it, instead I must use 24 bit RGB. What did I do that could possibly cause this to happen? If I select WinFast TV2000 XP WDM Video Capture I see nothing at all but I can see the VCR when I set it to Microsoft WDM Image Capture. I've looked at the Doom9 guide as well as other guides and threads here.
I also noticed that the software that came with the Capture Card, WinFast PVR, allows for uncompressed AVI recording using HuffyUV. I tried capturing with it and the quality didn't look bad. What downsides are there to using the WinFast software? I suppose I don't know if I'm capturing in YUY2 or RGB as I don't see a setting to choose which one to use.
Any help is appreciated
Results 1 to 1 of 1
Hauppauge 1212 HD PVR & VirtualDub
By MakiManPR in forum Capturing and VCRReplies: 3Last Post: 23rd Oct 2011, 12:31 -
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 17:24 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 13:13 -
Connect Winfast PVR 3000 via CD-In 4-pin on SB X-Fi Titanuim Fatality...
By retroborg in forum ComputerReplies: 2Last Post: 11th Oct 2008, 17:33 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 22:46
