Does anyone know the best way?? i have videostudio 5.0 and i just started capturing with it. in the beginning it let me choose which codec i wanted for compression(i used huffyuv) but then the option for me to choose which codec i want just simply DISAPPEARED!! i mean does anyone know how to bring it back?? thanks for ur time
AnonymousGuest
You might just want to choose another program... did you actually PURCHASE Videostudio, or was it bundled with something?
If you're capturing Huffy, I would highly suggest Virtualdub instead. Then you could encode the AVI to whatever using Ulead (though I would not reccomend it, try TMPGEnc or CCE instead).
Ulead products (Videostudio, DVD MovieFactory, etc) are very simple to use, and seem to edit fairly well, but I have rotten luck getting them to capture properly or encode well.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 15:46 -
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 21:08 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
video capture problems in ulead videostudio 11
By scott114 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 16:49
