Hi,
I tried searching the forum, but could not find a problem similar to mine.
I have a mpeg1 file from the internet. It lasts 24:48 min according to WMP and VD. The file starts out fine with video and audio. About 5:30 mins into the file however, there are 5 frames with some block errors and you can hear a small pop sound. After that the video continues to play just fine, but there is no audio. This happens both in WMP and VD.
According to VD, the audio is:
Format: 44KHz stereo, 224Kbps layer II
# of frames: 56970
Total size: 40693K
I should perhaps mention that the video is # of frames: 44599
A small calculationg suggests that the sound should be: 40693*8/224/60=24,22... mins long which in my mind would suggest the audio is there (provided VD is correct), it is just not played.
What should I do? Can i repair the file somehow?
Use virtualmod to open the mpeg , and strip the audio out as wav , and check .
This pop may have killed the audio completely from this point ... silence filled .
It happened in anacoda ... the issue was with the original dvd I had . -
Thank you for your help. I dl the newest version of VDM from their website (1.5.10.2), which is however somewhat older than the newest VD version, anyhow, no real difference, same problem (exporting to wav in VD and VDM makes no difference, same silence in wav file).
I could also note, that the popping sound I mentioned is hardly audible, you have to listen carefully to hear it at all.
Other suggestions? -
The easiest test would be to encode the file to another format - load it in convertXtoDVD or Tmpgenc and see if the conversion fixes the audio.
I'm pessimistic that the audio is there.
missing sound
By agent222 in forum Video ConversionReplies: 6Last Post: 27th Mar 2009, 10:51 -
WinFF_dvr-ms to XVID_no sound when played back by Linksys extender dma2100
By Ang in forum Video ConversionReplies: 4Last Post: 17th Nov 2008, 00:11 -
Subtitles missing when played on DVD Player
By bmwr51 in forum SubtitleReplies: 10Last Post: 18th Apr 2008, 14:10 -
V-CD: Both Sound Track are played in Media player classic
By cordeliamars in forum AudioReplies: 10Last Post: 28th Aug 2007, 11:25 -
DVD sound is terrible played back on stand alone players
By nikoz in forum Capturing and VCRReplies: 0Last Post: 12th May 2007, 19:13
