I know there are a few more features in ImgBurn, but I'll never use them. I use CloneDVD + AnyDVD to rip, so I really don't care that DVD Decrypter can rip DVDs. Is there any advantage to using ImgBurn over DVD Decrypter to burn .iso images? Is the burning engine better or updated in some way that would give me better burns? Thanks.
-Brett
Have you actually even read a sentance or two about either ??
https://www.videohelp.com/tools?tool=ImgBurn
ImgBurn carries on from where DVD Decrypter left off! ImgBurn can write most types of CD / DVD images and it supports all the latest writers (including booktype / bitsetting on many of the major ones - i.e. BenQ, LiteOn, NEC, Plextor, Sony). Create ISO's from files on your hard disk, or burning them direct to a disc. You can even use ImgBurn to erase / format your rewritable
Originally Posted by smitbret -
Yep, I have read about them. What I thought I was asking was whether or not I will get better quality burns of my .iso images (DVD-5) by using ImgBurn instead of DVD Decrypter. I really don't give a crap about the rest of that stuff.
-Brett -
If Decrypter works fine for you now, then no, no difference.
If you have issues with your newer burner not being seen in Decrypter, or you want to burn DL ISO's, then I'd have to suggest ImgBurn.
I use both.Want my help? Ask here! (not via PM!)
Searching the changelog (available here) of all changes since DvdDecrypter for anything related to the dvd-5 disks (all you're interested in), there isn't anything that would affect your results if you're using -R, but there are changes that would be considered improvements if you're using +R.
In a nutshell, use either program for -R SL, use ImgBurn if you're using +R SL. Also (as lordsmurf recommended), if you do develop an interest in burning DL, then ImgBurn is preferable.
I/O errors using ImgBurn and DVD Decrypter
By jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 14:58 -
Decrypter to Shrink to Imgburn?
By visionman in forum DVD RippingReplies: 3Last Post: 19th Jan 2011, 12:06 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 17:47 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 15:21 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 10:05
