i bought a toshiba dr-5 and i have a hd digital box. how do i hook it up to record from the digital box? pics would help a lot. also am i able to record shows while i'm watching tv?
What's the brand and model of your 'hd digital box' and what service is it using? Someone here may be using a similar setup.
All you need to do is connect the video output (s-video or coax)of the cable box into the video input of the recorder.
The only problem you may have, is how your cable box is currently connected to your TV. I assume that since you have a "HD digital box", that you are using HDMI or component from the cable box to your TV. Many units disable the other video outputs when using HDMI. If that is the case, you would have to disable the HDMI output whenever you wanted to use the recorder. The only way to know for sure is to try it.
The recorded will only record the channel selected on the cable box, but you can still watch it while it is recording.Google is your Friend -
can i hook up the cable directly into the recorder, then hook up from the recorder to the cable box then from the box to the tv?
not sure if my explanation was clear but will that work?
Does a DVD recorder need digital tuner to receive content from a cable box?
By True Colors in forum DVD & Blu-ray RecordersReplies: 23Last Post: 18th Apr 2014, 10:17 -
Digital Converter Box for TV (how to hook up)
By jay333 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2013, 22:02 -
digital converter box question
By woot_joe in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2009, 15:29 -
DVD recorder + digital cable question
By bigkromedogg in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Sep 2007, 11:34 -
Digital Cable Box, DVD Recorder, Television Hook Up Problems!
By robdawg70 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Jul 2007, 15:35
