Hi Guys,
I'm having real problems in converting the demultiplexed mp3 audio from
http://video.google.com/videoplay?docid=8068309038544717701
to wav or mp2. It plays ok in Audacity and lots of other audio programs but simply won't convert to DVD compatable audio - all I get is silence. I'm aware that the sampling rate and bit rates are ridiculously low, I don't care - I just want the content on DVD; the audio recoders should be able to cope with the highly disparate bit rate & sampling rates.
I have no problems with the video, anything that can open using direct show will convert the video.
Has anyone else had similar experience with this type of file that could lend me a hand.
PN
Well, seeing as it's a 350 MB avi file I didn't want to download all of it. But a sample was enough for AVIcodec to identify it as 128 kB MP3, sampled at 44k. Which isn't hifi, but isn't ultra low.
I grabbed the first 5 MB, demuxed it, and ran BeSweet.
I ran into probably the same problem you did when converting it directly to MP2; just hiss.
So I converted it first to WAVE, then converted the WAVE to MP2. That seems to work.
BeSweet Log:
Code:BeSweet v1.5b31 by DSPguru. -------------------------- Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Logging start : 01/09/07 , 01:26:24. P:\BeSweet\BeSweet\BeSweet.exe -core( -input Q:\00\BBCHorizonRichardDaw.avi.mp3 -output Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24].wav -2ch -logfilea P:\BeSweet\BeSweet.log ) -ssrc( --rate 48000 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : Q:\00\BBCHorizonRichardDaw.avi.mp3 [00:00:00:000] | Output: Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24].wav [00:00:00:000] | Floating-Point Process: No [00:00:00:000] +------ Shibatch ----- [00:00:00:000] | Source Sample-Rate: 44.1KHz [00:00:00:000] | Dest. Sample-Rate: 48.0KHz [00:00:00:000] | Attenuation : 0.0db [00:00:00:000] +--------------------- [00:00:53:497] Conversion Completed ! [00:00:53:497] Actual Avg. Bitrate : 765kbps [00:00:02:000] <-- Transcoding Duration Logging ends : 01/09/07 , 01:26:26. BeSweet v1.5b31 by DSPguru. -------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using MP2enc.dll v1.129 (23/5/2002), Engine 1.129 <http://www.cdex.n3.net>. Logging start : 01/09/07 , 01:27:16. P:\BeSweet\BeSweet\BeSweet.exe -core( -input Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24].wav -output Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24] - New - [09.01.2007] - [01.27.16].mp2 -logfilea P:\BeSweet\BeSweet.log ) -ssrc( --rate 48000 ) -toolame( -m s -b 128 -e ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24].wav [00:00:00:000] | Output: Q:\00\BBCHorizonRichardDaw.avi - New - [09.01.2007] - [01.26.24] - New - [09.01.2007] - [01.27.16].mp2 [00:00:00:000] | Floating-Point Process: Yes [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +------- MP2ENC ------ [00:00:00:000] | Bitrate method : CBR [00:00:00:000] | MP2 bitrate : 128 [00:00:00:000] | Channels Mode : Stereo [00:00:00:000] | Error Protection: Yes [00:00:00:000] +--------------------- [00:00:26:656] Conversion Completed ! [00:00:26:656] Actual Avg. Bitrate : 128kbps [00:00:01:000] <-- Transcoding Duration Logging ends : 01/09/07 , 01:27:17.
Originally Posted by Panash
As for Besweet, note I went to MP3 to WAVE first, then WAVE to MP2.
I used the Wizard interface which generates the command lines shown in the logfiles. -
I used a third party download site (I'm M$ Explorer rather than Firefox based) and I believe that I captured the Win/Mac version, as you did. I may download FF & use that to down load the avi file.
PN
format to use for fastest conversion from flv
By cduval04 in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 00:58 -
Help: How to convert .rad to other format (mp3/wav/ogg/etc)?
By Nator in forum AudioReplies: 1Last Post: 11th Sep 2008, 20:06 -
FLV format conversion to MPG4
By Simon5005 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2008, 10:09 -
What is the best export format from Vegas for later FLV conversion?
By Gargalash in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 00:20 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 04:13
