My 510 came with a dvd writer 106. It is burning the 8x disks but I am not able to view them once I open & close the tray of the burner. The burner does not even recognize the 16x disks. SO I went and bought a new pioneer dvd burner DVR 111D. I have the service disk GGV1179 and the palm remote. Has anyone been able to successfully upgrade the DVD burner using these?
A few questions:
a) there is 2 wire cable connecting the current dvd burner to the 510H-s. That slot is missing in DVR 111D. Anyone know what that is for? Do I still need it?
b) Do I need a seperate firmware cd / dvd for my pioneer machine to recognize the new dvr 111D?
c) What would be the process for the 510H-S to recognize my DVR-111D?
I had succesfully upgraded my hard disk in 510 from 80 to 320GB. the post is here
https://forum.videohelp.com/viewtopic.php?t=253998&postdays=0&postorder=asc&start=270
I am hoping that I will be able to replace the burner in a similar fashion.
Any and all help would be appreciated.
Results 1 to 9 of 9
Several forum members have been able to replace/repair their pioneer (510hs and 520hs) burners. I succeeded with my pioneer 530hs. My guess is that the procedure is easier with the 510hs and 520hs. [btw, I'm almost certain one or two members attempted the replacement with using the pioneer 111D writer - check those threads on this forum.] Here is the link to the procedure I used with my 530hs:
https://forum.videohelp.com/viewtopic.php?t=304500&start=30
R/James -
james before you deleted the cprm data was the new dvd burner making noises (opening and closing)?
The DVD drive was opening and closing, not allowing DVD vs. HDD selection, making sounds, not powering off, etc. I tried deleting and re-inputing CPRM data to no avail. The problem was the jumper setting (I believe correct setting is "master") - once I placed the jumper in correct position and deleted and re-entered CPRM ID#, the drive worked and has continued to work as new.
I have tried all jumper settings. I am trying to replace my 106X with 108 or 111D. Every time I connect it to the DVR it starts making noises (tray opening and closing). Both work in my computer though.
I think it has to do with the firmware issue. I think the 510 is not recognizing the newer burners. -
Originally Posted by pendu2004
Still wondering if you were ever able to make the new drive work??????
Please let us know!!
Peace. -
Does anyone know where I can get the Pioneer DVR-510H service manual and the service dvd? I need to replace my hard drive in the unit and cannot find either items anywhere. I've searched the website links on this site and unfortunately cannot get the items. I have the service remote, actually created one myself, just need the manual and the dvd, thanks.
Thank you,
Keith
keithsigr@yahoo.com
replacement DVD drive for pioneer 420h/520h
By nrobinson in forum DVD & Blu-ray RecordersReplies: 7Last Post: 11th Jun 2025, 16:12 -
PIONEER DVR-520H-S
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Jun 2011, 02:18 -
pioneer dvr-520h please shuts off !!!!
By motin in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Nov 2010, 07:24 -
Pioneer DVR-520H Can't finalize.
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Jan 2009, 22:30 -
Pioneer DVR 520H and HDTV
By WCM in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Feb 2008, 13:38
