Situation:
I have a dozen DVD's of home videos that were authored about four years ago. (I think on pinnacle, but that probably doesn't matter. I don't have any of the original material in any other form.
For some reason (probably an automated process in the original authoring program) this material has a chapter break every minute or so.
I am consolidating and reauthoring some of these with menus and the enoumous number of chapter breaks is unwanted and creates problems in navigation
Need:
I wish to remove some/all of the chapter breaks. Seems I should be able to do this in a lossless way. I am hoping for a solution freeware. Thanks in advance
If you are re-authoring them, just don't import any of the chapter info into the authoring program you are using
Every authoring program i have ever used either does not auto import this info or ask's first whether you want to or not. Then just add new one's where you want.
FFmpeg - Removing commercial breaks from mpeg TV recording
By Chris_Smith in forum Video ConversionReplies: 0Last Post: 19th May 2009, 03:43 -
create chapter breaks that return to menu afterwards using PGCedit ?
By spiritgumm in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2009, 09:07 -
Removing a chapter from a title
By GrayStrickland in forum EditingReplies: 2Last Post: 22nd Nov 2007, 01:52 -
DVDauthorGUI chapter breaks cheatsheet
By AlecWest in forum Authoring (DVD)Replies: 8Last Post: 12th Jul 2007, 01:20 -
Want to add chapter breaks to a video. Suggestions please.
By Super Warrior in forum EditingReplies: 3Last Post: 27th May 2007, 13:56
