Hi,
I'm a newbie to DVD authoring and would like some advice.
I have a sony DVD camcorder and have created numerous DVD's with no problem. However I have one DVD where the volume is quite low about half way through and would like to increase the volume just in that area (lasts about 1 minute) the audio on the rest of the DVD is fine. Is that difficult to do?
Thanks in advance!
It requires some work yes. One method:Originally Posted by dcookster
Split the video and audio from the DVD using PGCDemux.
Open the audio in Goldwave, select the part which has low volume and increase it.
Save as WAV 48khz.
You might have to convert the wav to ac3 if it's too big for the dvd, use for example ffmpeggui.
Reauthor the video and the new audio to a new DVD using an authoring tool like Tmpgenc dvd author. If you want the same menus as the original DVD read https://www.videohelp.com/guides.php?guideid=937#937
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 06:41 -
Increasing volume in GKnot
By Fire Foxer in forum EditingReplies: 6Last Post: 7th Aug 2009, 08:08 -
increasing volume in mp4 video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 00:05 -
increasing the volume of ac3 files
By virendra in forum AudioReplies: 4Last Post: 1st Nov 2007, 03:25
