Is one method of encoding avi files or DVD's to ipod compatible video better than another as far as the video sound and quality go? Or is it all just the same?
Smile
Smile -
It would generally be all the same. If you start with the same file, the encoding settings are what determine the quality, both audio and video, assuming you are using the same codecs with each encode. Some programs may give you easier ways to adjust the settings, but still, they are still using the same codecs.
In a conversation with a Mac owner, I mentioned the method in which you could use Nero Recode to convert any avi files to ipod compatible video. He then says "With a MAC you could do the same thing with just a few clicks, but...whatever." Just wondering what I can say to thatOriginally Posted by redwudzSmile
Smile -
I'm not sure how much his Mac costs, but he said the software was free.
Smile
Smile
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
