I am using this guide...
http://club.cdfreaks.com/showthread.php?t=139536
My problem is that when the DVD Decrypter created the AC3 files, they will not play in anything, and Nero won't even recognize them. They are in the folder tho. I tried using the other guide that uses Goldwave but Goldwave constantly freezes up on me when I add in the AC3 file.
Any ideas?
You probably need a AC3 codec. You can use AC3 ACM Decompressor and open them with VirtualDub and convert them to other formats. Or there is also AC3 Filter for decoding. Sorry, I haven't tried to edit them, just convert them to other formats if needed. If I want to use them in a DVD, I just mux them out of the original video and add them in without changes when I author the MPEG file to DVD format.
If you just want to convert them to WAV, I use the AC3 ACM Decompressor and put the whole video file into VirtualDub Mod, then save out the audio as a WAV with full processing settings. If I need to edit the WAV, I use the freeware Audacity audio editor, then output as WAV again. Then you can use ffmpeggui to convert the WAV back to AC3, 2 channel. -
Back to the original question. Do any of the above suggestions work with the DVD Decrypter's extracted AC3 files? I am curious of the answer to that.
Darryl
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 22:41 -
Converting WAV to AC3 - sound loss
By MackemX in forum AudioReplies: 10Last Post: 19th Mar 2009, 16:15 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 21:25 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 20:24
