Ok - I have tried ther newest and the oldest available CODEC of XVID.
Both shutdown the program using it whwen you select a file.
Both will often times freeze Windows Explorer.
Windows 'report This Porblem' actualy worked for once and reported that removing the XVID Codec will resolve the problem with Single Core CPUs - It does!!
But - I (think) I need XVID.
Any fixes for it out there? (Other than buying a dule+core cpu!)
Any alternative?
Thnaks
Shutdown what program? If you are having this issue with playback, then it's likely not the Xvid codec. Have you installed any codec packs lately? Or are you trying to encode with the codec?Both shutdown the program using it whwen you select a file.
I'm guessing you have a codec conflict. The Xvid codec doesn't care how many cores you have. It may run faster when encoding with a dual core machine, though.
Usually when explorer freezes up when opening a Xvid file, it means the file is corrupted or you have one too many codecs interfering with each other. If this is a playback issue, try installing VLC media player. It uses it own codecs, so the installed system codecs aren't used. If it works for playback, then you likely do have a codec problem.
And welcome to our forums.
Quad Core Encoding, Xvid or X264
By kidcash in forum DVD RippingReplies: 20Last Post: 8th Feb 2010, 06:46 -
Media Player Classic Single Core only?
By fitch.j in forum Software PlayingReplies: 1Last Post: 16th Jun 2009, 08:15 -
xvid only using one core
By sumpm1 in forum LinuxReplies: 6Last Post: 14th Sep 2008, 01:01 -
Dual Core or single does it really matter for captures. Which mainboard?
By gll99 in forum ComputerReplies: 114Last Post: 16th Aug 2008, 17:16 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 15:45
