Hello. A friend of mine in Japan burnt some DVD movies for me. Eight of the ten movies are fine and I have no problems with audio or video playback. I'm having problems with the audio of the other two movies. The video plays fine but there is no audio when I use my Pioneer and Panasonic standalone players. I've played the movies on my computer but there is still no audio. My friend advised me I'm missing some audio codec.
Using DVD shrink, I found a 160 MB AC3 2-ch unspecified audio file on the DVD. I've ripped the VOB files using SmartRipper and then using DVD2AVI converted the AC3 file to a WAV file. Playing the Wav file, there is still no audio.
I've downloaded and installed AC3Filter and but that doesn't work. I've tried using other media players including VLC but no audio. I'm at my wits end here.
Is there anyway of converting the AC3 audio file to a playable format so I can hear something? I’m looking to reburning both movies so I can watch them properly. Or did my friend screw up the DVDs and I will now have to get replacements? Any advice will be appreciated.
wkl
All DVD players can by definition play AC3 audio. My guess is that there simply is no audio.
/Mats -
Try to download g-spot, and check your DVD with it. It will tell you what is on that DVD.
http://www.headbands.com/gspot/download.html -
It sounds like (pardon the pun) that the audio is just a track of silence ie: the audio track is just one long track of silence totallying 160mb ... my guess is that the dvd from which this movie came was not ripped correctly ... or if this is a homemade movie then it was either encoded or authored incorrectly
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
