I received my Contour Shuttle Pro v2 the other day and loaded the software drivers on the CD Version 2.0. I was wondering for anyone whom is using it what settings you have changed to your button preference to accommodate your editing techniques? Here is what comes on cd. I am using it with Adobe Premiere 6.0
1) Lift
2) Default transition
3) Overlay source clips at edit line
4) Insert source at edit line
5) Go to previous
6) Reverse play
7) Stop
8) Forward play
9) Go to next edit
10) Clear in point/marker
11) Clear out point/marker
12) Toggle source and program
13) Toggle monitor and timeline
14) Set in point/marker
15) Set out point/marker
Jog Dial
Jog left>reverse frame
Jog right>forward frame by frame
Shutter > rewind.... And so on
