I record and edit a number of tv shows daily and am getting a mad about the editing. I am usint the latest TMPGEnc mpeg tools. I have 576mb ram. i encode the shows at 320x240, 1.15mbit ( so i can fit 3 edited shows on a 700mb cd). When i am editing it it will say for example:
Video Part: 546.67 secs
Audio PartL 546.67 secs
when they are the same the outputted file will be just slightly out of sync, when they are slightly different the video will be in-sync. The original is perfectly ins ync all the way through. What can i do? is there any video performance settings i can use in Win2000? also what services do i need running in Win2000. Any help will be greatly appreciated.
Bob
It seems you are not alone--alot of people(including myself) get a/v synch problems after running through tmpgenc, and some people get perfect results--i guess it depends on certain things but I have no idea what they are. I have gone to vcd cutter to edit mpeg-1 and it is about 500% quicker with no synch problems (at least on my setup
) I guess you just have to experiment to find one thats good for your system.
Mpeg-2 editing confusion...
By amtt in forum EditingReplies: 41Last Post: 3rd Mar 2011, 17:47 -
editing program - sd mpeg
By devdev in forum EditingReplies: 5Last Post: 21st Oct 2010, 12:53 -
MPEG editing
By mkr10001 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 23:54 -
Keyframes and MPEG-2 editing
By ffooky in forum MacReplies: 8Last Post: 5th Feb 2009, 04:17 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 04:52
