    Jan 2007
    I do exactly as a guide says you should do.
    But every time i try (have tried with different movies) i only get this message: Avisynth open failure:
    AVIsource: couldnīt locate a decompressor for fourcc xvid
    (D:\Film\Avi2dvd_temp\Avisynth_Script_File.avs, line 2
    The error shows when after it have convert the sound. Hope anyone can help me.
    This was shown in the log:
    [01:11:15] AVI2DVD Started !
    [01:11:17] Type mode : Avi Input
    [01:11:17] Output : Dvd
    [01:11:17] Encoder Selected : QuEnc
    [01:11:17] Start demuxing the AudioStream No.1 ...
    [01:11:27] Demuxing of the selected audio finished
    successfully ! [D:\Film\Avi2dvd_temp\Extracted_Audio.mp3
    41808336 Bytes]
    [01:11:27] Starts Audio correction ...
    [01:11:31] Audio Fixed successfully !
    [D:\Film\Avi2dvd_temp\Fixed_Audio01.mp3 41808336
    Bytes]
    [01:11:31] Starts Mp3->Ac3 convertion ...
    [01:15:30] Audio converted in Ac3 successfully !
    [D:\Film\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3
    119132160 Bytes]
    [01:15:30] Start creating avisynth script ...
    [01:15:31] Avisynth script created successfully !
    [D:\Film\Avi2dvd_temp\Avisynth_Script_File.avs 168
    Bytes]
    [01:15:31] Bitrate used : 7616 Kbpps
    [01:15:31] Start video encoding ...
    [01:18:50] Video encoded successfully !
    [D:\Film\Avi2dvd_temp\Encoded_Video.m2v 0 Bytes]
    [01:18:50] Job NOT Done. There are warnings ... Find at
    the log file the 0 byte generated file to focus where exactly
    the problem appears
    Install koepis xvid codec.
    And this is no dvd to conversion. Moving you.
