    Nov 2001
    Using DVDRemakePro it is easy to remove FBI warning but another warning comes up saying "the views and opinions expressed are those of..." but I cannot find this anywhere in the dvd structure. Any ideas where this could be hidden?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    it's usually a small vob file as well, look at them all till you find it. Unless it was made part of a menu, then it might be harder to get rid of.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    It can be anywhere in new DVDs, often attached to a movie.
    Yesterday I found a warning in title menu PGC, as an internal part of introductory clip preceding the stills, it couldn't be hidden the usual way with DVDRemake being a small part of a useful block.
    Feb 2004
    Australia
    It's possible such exist's as cellid 1 in the actual title's vob structure , and this is why it is not showing up the way you think it should .
    Depending on how it is done you have choice's ... vobblanker , but if this is part of the title , and dose not include a seperate cellid , it will need splitting up before using vobblanker to remove it .
    A bit of work required using vobedit , muxman and this guide show's how to generate the required celltime's text which will cause the splitting ... https://forum.videohelp.com/viewtopic.php?t=291744
    You would also need vidchanger to change the cellid to 1 , as the part you want would have cellid 2 , which might cause conflict with the menu navigation when it come's down to chapter sellections ... ect .
    Oct 2005
    You could also use PgcEdit in Trace mode to find the cell(s), then put a tick in the "Blank this cell" box on the preview screen.
