  1. Member Soopafresh's Avatar
    Jan 2004
    I've liked the app ever since it was the free "DivxtoDVD". Recently installed the eval of the commercial product and began noticing video playback stuttering on my PC - even with files which played back fine before...
    Using DriversView by Nirsoft, I discovered the Pattin-Couffin driver had been installed. Uninstalled ConvertXtoDVD and it uninstalled Pattin-Couffin. Voila, my PC was back to playing media files without stutter.
    I'm sure VSO is working on a fix for this (they're very smart guys), but just in case you're experiencing similar behavior on your system....
    USA
    I haven't noticed any problem with playback with VLC or Zoom. I have ConvertXToDVD 2.1.8.193 and have used earlier versions for some time that had the Pattin-Couffin engine.
    EDIT: Looking around, that is apparently the burning program for ConvertX. Or a replacement for the ASPI layer, not sure which, but a bunch of VSO programs seem to use it.
  3. Member Soopafresh's Avatar
    Jan 2004
    Hmmm. Maybe it's the specific combination of everything on my system. Pcouffin might have been the piece that made it unstable. http://www.hasbro.com/jenga/
    Dec 2004
    Australia
    Yeah it also comes with BlindWrite, etc. and has done for years. Never had any issues with it here (Don't have ConvertX installed though).
  5. Member Soopafresh's Avatar
    Jan 2004
    I am so sorry. It was one of my drive channels - set to PIO for some reason.
    Feb 2004
    Australia
    It's also include with some tool's that create phantom drives ... alcohol I think dose , and I had no issue's with it ... didnt like it being there , but it wasn't affecting my pc's at any time .
  7. Mod Neophyte redwudz's Avatar
    USA
    Not a problem. I tore half a computer apart once because of a keyboard problem it suddenly developed. The actual problem was that the keyboard was plugged into the mouse socket.
    I always thought Windows should have a pop up when a drive channel reverts to PIO. If you have a lot of problems when reading a disc with an optical drive, after six failed attempts, Windows reverts the drive channel to PI0 mode.
    It's a Windows 'feature' to let the drive continue to work. That causes a lot of mysterious slowdowns and read and write problems. I don't know if they fixed that in Vista, but we can always hope.
